Автор Тема: E29940704  (Прочитано 693 раз)
E29940704
« : 07 Сентября 2016, 14:44:14 »
E29940704
Event ID
E29940704   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:16:45 PM
Subject
Dead, CN6400
Unit does not work, no indication of power.
[Primary Symptom Code: 1111 ]
Solution
Reconnected CN6400 plug to main power board.
CN6400 on the G11 Board to CN8200 on the AL Board.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
CN6400.JPG   CN6400
Model Details
KDLV26XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    STE   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8011174    8011174    STE   9/1/2005   MIX5   40   TV and Display (TVP)
