Автор Тема: E29928691  (Прочитано 808 раз)
E29928691
« : 07 Сентября 2016, 14:43:12 »
E29928691
Event ID
E29928691   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
10/18/2007 11:38:10 AM
Subject
No or Distorted picture symptoms
No or Distorted picture symptoms.
[Primary Symptom Code: 118X ]
Solution
1. SYMPTOM: Line in middle of picture.
SOLUTION: Found CN5403 on the B Board was loose.
Remounting restored operation.
2. SYMPTOM: Vertical dots through out screen. On all inputs. OSD is affected.
Has multiple white dots with purple inside the dots.
SOLUTION: Replacing B Board resolved the symptom.
A1147799A 152 B Board (KDL-V26XBR1)
3. No picture and has backlight.
SOLUTION: Replaced the QM board and set is now fixed.
4 Dead with 9X error.
SOLUTION: Found GI2 board cause of 9X. See T/M Chart 9X attached..
5. Unit has 2 horizontal lines on screen. One line is about 8 inches from top and the other 8
inches from bottom with a space in between them. They are visible with all inputs and also
visible with no input to panel. They go away with HDMI input. As soon as you unplug HDMI,
the line reappear. Lines do not affect the menu or OSD on screen.
Replacing the AL Board resolved the issue.
AL Board A1147-795-A (KDLV-32XBR1 Only)
6 Digital vertical lines, (like E31346481) not there on video 7 and OSD OK.
Replaced B board. P/N A-1147-798-A (KDL32XBR1 Only).
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
CN5403.JPG   CN5403
TM.pdf   Training Manual 9X
Model Details
KDLV26XBR1    SEE    SOLUTION    INY   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    INY   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    SEE    SOLUTION    INY   9/1/2005   MIX5   40   TV and Display (TVP)
