Автор Тема: E29653976  (Прочитано 701 раз)
E29653976
« : 07 Сентября 2016, 14:24:50 »
E29653976
Event ID
E29653976   Type
Break/Fix Info    Level
4   Safety Issue
No   AutoFlag
No   Last Update
6/28/2006 7:18:19 PM
Subject
Leans on the stand about 5 degrees forward.
Set leans on the stand about 5 degrees forward.
[Primary Symptom Code: 118X ]
Solution
The bracket and the mounting support for the bracket was bent inside the TV.
This is physical abuse and therefore not covered under warranty.
Notes:
The P/N listed for boards, or components COULD be based on the sets model
and/or serial number.
Supporting Documents
File   Description
bracket.pdf   Bracket location
Model Details
KDLV26XBR1    SEE    SOLUTION    INY   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV32XBR1    SEE    SOLUTION    INY   9/1/2005   MIX5   40   TV and Display (TVP)
KDLV40XBR1    8013618    8013618    STE   9/1/2005   MIX5   40   TV and Display (TVP)
