Автор Тема: E26163574  (Прочитано 820 раз)
E26163574
« : 07 Сентября 2016, 14:13:32 »
E26163574
Event ID
E26163574   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
1/10/2005 2:06:34 PM
Subject
Memory Stick PRO can not be read, software upgrade
NOTE: The serial number labels are on both the back of the Display and the MRU.
The serial number range given is for the MRU's not the Display unit. The QH Board for Models:
KDE-42XBR950, KDE-50XBR950, KDE-61XBR950, KDL-32XBR950, and KDL-42XBR950 are located in the MRU.
The reason for this is the MRU's can be matched with any given Display unit from the same family. I.e. an MBDXBR950 can be connected to a KDE-42XBR950, KDE-50XBR950, or KDE-61XBR950 Display section.
TV has a Memory Stick Pro compatible media viewer, but when Memory Stick Pro media is used (both Sony brand and non-Sony brand), it appears as if the TV can not read the data from it correctly. Other non Memory Stick media (none Pro type) seem to work fine.
Possible symptoms include:
* Getting an error message on the screen after inserting the MS PRO media.
* The pictures not displaying properly in index mode, expanded full view or in sideshow mode.
* Receiving an error message or automatically returning to index mode when attempting to
rotate, protect an image or during other operations when the TV is interfacing with the MS
PRO media.
* Whole or partial damage to individual files, more than one file or possible damage to the Memory Stick PRO media itself.
NOTE: Sony recommends backing up all images onto a PC or other media before displaying them in the Media Viewer on your TV.
CAUSE:
A) The Memory Stick Viewer board firmware (software) has an incompatibility with some types of Memory Sticks Pro media. For this reason, the TV can not access images stored on it.
B) The Memory Stick Viewer board hardware can not provide enough current to some types of Memory Sticks Pro media.
[Primary Symptom Code: 117X ]
Solution
Replace with a new Memory Stick Viewer board which has both Countermeasures on it.
See the attached table and picture of the location of R1337 on the HM Board.
Supporting Documents
File   Description
Table.pdf   Table
Model Details
KDE42XBR950    SEE    NOTE    PITT   12/1/2003   NONE   40   TV and Display (TVP)
KDE50XBR950    SEE    NOTE    PITT   12/1/2003   NONE   40   TV and Display (TVP)
KDE61XBR950    SEE    NOTE    PITT   12/1/2003   NONE   40   TV and Display (TVP)
KDF60XBR950    9000000    9002560    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDF60XBR950    9100000    9108168    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDF70XBR950    9000000    9003243    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDF70XBR950    9100000    9104526    PITT   10/1/2003   LA2A   40   TV and Display (TVP)
KDL32XBR950    SEE    NOTE    PITT   12/1/2003   NONE   40   TV and Display (TVP)
KDL42XBR950    SEE    NOTE    PITT   12/1/2003   NONE   40   TV and Display (TVP)
KDP51WS550    9700000    9708875    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP51WS550    9800000    9800485    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP57WS550    9700000    9709455    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP57WS550    9800000    9801007    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP65WS550    9700000    9705484    PITT   7/1/2003   AX1   40   TV and Display (TVP)
KDP65WS550    9800000    9802132    PITT   7/1/2003   AX1   40   TV and Display (TVP)
MBDXBR950    2000000    2012169    PITT   12/1/2003   NONE   40   TV and Display (TVP)
MBDXBR950L    2000000    2004750    PITT   12/1/2003   NONE   40   TV and Display (TVP)
