Автор Тема: E24394566  (Прочитано 801 раз)
E24394566
« : 07 Сентября 2016, 14:11:38 »
E24394566
Event ID
E24394566   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
5/27/2004 12:02:53 PM
Subject
Fan Failure error: Media Box
I am getting a message on the screen that states Fan Error.
[Primary Symptom Code: 213X ]
Cause
A Fan error or Fan stopped may occur caused be a defective lot with excessive grease applied to the bearings. This causes the fan to stop at abnormal positions. When the unit is turned on again the fan may fail to start.
Solution
NOTE: The serial numbers specified within this bulletin are for the Media Receiver Unit (MRU). Please make sure that you are looking at the serial number of the MRU and NOT the Display Section serial number.
Step 1) There are two (2) fans in the MRU. One fan pulls air into the box while the other pushes it out. Please note the proper position and installation as you may need to replace the fans and the correct installation is critical.
Step 2) Verify that the G board (Inside the MRU) is providing voltage to the fans. This can be done by pressing the power on button and checking G bd. CN 6101, pins 1 and 3. They should be 7.7VDC. Also verify that G bd. CN6005, pin 9 is 3.1VDC. The 7.7VDC is for power the fans and the 3.1VDC is the fan control to turn them on. If both of these voltages are present can the fans (part number 1-787-088-11). If one or more of these voltages are incorrect or missing replace the MRU (authorization required).
Model Details
KDE42XBR950    2000001    2010396             40   TV and Display (TVP)
KDE50XBR950    2000001    2010396             40   TV and Display (TVP)
KDE61XBR950    2000001    2010396             40   TV and Display (TVP)
KDL32XBR950    2000001    2001686             40   TV and Display (TVP)
KDL42XBR950    2000001    2001686             40   TV and Display (TVP)
MBDXBR950    2000001    2010396             40   TV and Display (TVP)
MBDXBR950L    2000001    2001686             40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
178708811    DC FAN   DC FAN   213X   PWA   CHASSIS    A   A
Diagnostic Codes
Type   Code   Description
U    213x    Counter Fan Failure Media Box
