Автор Тема: E24045905  (Прочитано 662 раз)
E24045905
« : 07 Сентября 2016, 14:09:20 »
E24045905
Event ID
E24045905   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
2/20/2004 6:10:20 PM
Subject
Part number: Display section
What is the part number for the display section?
[Primary Symptom Code: 118X ]
Solution
The part number is T99861284. Authorization is required for this part.
NOTE: The following boards (DES, G2, K1, K2, T, R3, R4) are field replaceable within the Display section so the technician should
consult the service manual and troubleshoot the TV to board level first and only change out the display section for panel
problems.
Model Details
KDL42XBR950    ALL    ALL    Iny            TV and Display (TVP)
LDM4210    ALL    ALL    Iny            TV and Display (TVP)
