Автор Тема: E24045840  (Прочитано 713 раз)
E24045840
« : 07 Сентября 2016, 14:04:00 »
E24045840
Event ID
E24045840   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/27/2009 6:25:51 PM
Subject
Part Number: Display section
What is the part number for the display section?
[Primary Symptom Code: 118X ]
Solution
The part number is T99861283.
Part is NLA
Set up for repair at location:
SONY WCSC
9255 Customhouse Plaza
Dock Door #6
San Diego, Ca. 92154
NOTE: The following boards (DES, G1, K, R1, R2) are field replaceable within the Display section so the technician should consult the service manual and troubleshoot the TV to board level first and only change out the display section for panel problems.
Model Details
KDL32XBR950    SEE    SOLUTION    Iny   1/1/2004      40   TV and Display (TVP)
LDM3210    SEE    SOLUTION    Iny   1/1/2004      40   TV and Display (TVP)
