Автор Тема: E24021705  (Прочитано 711 раз)
E24021705
« : 07 Сентября 2016, 14:03:01 »
E24021705
Event ID
E24021705   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/27/2009 4:57:39 PM
Subject
Troubleshooting by the Diagnostic Codes
How do you troubleshoot by the Diagnostic Codes?
[Primary Symptom Code: 118X ]
Solution
MRU Blinking 9 times and Display section LED is flashing RED/GREEN, RED/ GREEN etc
-Plasma Panel or plasma Circuit boards are at fault.
MRU Blinking 9 times and Display section LED is flashing 7 times
-Audio problem. Check K board.
MRU Blinking 9 times and Display section LED is flashing 6 times
-Power supply problem.
Check G, G1, G2, F1 and F2 boards as applicable to the model.
MRU Blinking 9 times and Display section LED is flashing 4 times
-Temp sensor has tripped. Make sure unit is in a cool area and fans are
operating in the display section AND Media Receiver Unit (MRU).
If the MRU Power/Standby LED is blinking:
9 Times, SEE ABOVE
10 Times, Over Voltage Problem, Change MRU
8 Times, Over Voltage Problem of DC-DC Conv. Change MRU
6 Times, Power failure, Change MRU
4 Times, Fan error, Check fans in MRU and display section
If the MRU LED is flashing ORANGE and the Display section LED is off
-Power cord of the display section is not connected or IF cable is not connected to the display section.
Also make sure that the MRU is the correct one for the Display section, see E23802956.
If the MRU LED is off and the Display section LED is flashing ORANGE
-Power cord of the MRU is not connected or IF cable is not connected to the display section.
Also check data connection cables for a bad connection or a damaged cable.
Supporting Documents
File   Description
E24876804-KDE42_50XBR950 Flowcharts Only.pdf   Flowcharts
Model Details
KDE42XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KDE50XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KDE55XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KDE61XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KDL32XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KDL42XBR950    ALL    ALL    INY         40   TV and Display (TVP)
KE42XBR900    ALL    ALL    INY         40   TV and Display (TVP)
KE50XBR900    ALL    ALL    INY         40   TV and Display (TVP)
KLV30XBR900    ALL    ALL    INY         40   TV and Display (TVP)
LDM3000    ALL    ALL    INY         40   TV and Display (TVP)
LDM3210    ALL    ALL    INY         40   TV and Display (TVP)
LDM4210    ALL    ALL    INY         40   TV and Display (TVP)
MBDXBR950    ALL    ALL    INY         40   TV and Display (TVP)
MBDXBR950L    ALL    ALL    INY         40   TV and Display (TVP)
MBTXBR900    ALL    ALL    INY         40   TV and Display (TVP)
MBTXBR900L    ALL    ALL    INY         40   TV and Display (TVP)
PDM4200    ALL    ALL    INY         40   TV and Display (TVP)
PDM4210    ALL    ALL    INY         40   TV and Display (TVP)
PDM5000    ALL    ALL    INY         40   TV and Display (TVP)
PDM5010    ALL    ALL    INY         40   TV and Display (TVP)
PDM5510    ALL    ALL    INY         40   TV and Display (TVP)
PDM6110    ALL    ALL    INY         40   TV and Display (TVP)
