Автор Тема: E23920721  (Прочитано 712 раз)
E23920721
« : 07 Сентября 2016, 13:50:47 »
Event ID
E23920721   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/23/2004 6:46:20 PM
Subject
Colored dots in pic when using 10-meter cable
I have colored dots in the picture which seem to come and go. Most noticable with dark scenes or no video displayed. Dots are mostly green. Customer has 10-meter cable connected between the MRU and display section.
[Primary Symptom Code: 118X ]
Solution
Some after market 10-meter cables from vendors other than Sony produce a cable that may not be of high quality. These cables can produce video problems in the display. Typically, if the cable is not of good quality, red, green, or blue lines will appear in the picture.
If using the VMCP10 (10-meter cable) please pay special attention to which end of the cable is plugged into the MRU and which is plugged into the display section. Some of the cables are polarity sensitive and will be marked on the connector housing. If the cable is marked it will have Display or Receiver on the black or white connector housings.
Display = connect to the display section
Receiver = connect to the media receiver unit
If no markings are present the cable is not polarity sensitive and can be connected in either direction.
Supporting Documents
File   Description
PicOfConn.JPG   ConnectorPic
PicOfConn2.JPG   ConnectorPic2
CableVMCP10_1.pdf   Instructions1
CableVMCP10_2.pdf   Instructions2
Model Details
KDE42XBR950    ALL    ALL    Iny            TV and Display (TVP)
KDE50XBR950    ALL    ALL    Iny            TV and Display (TVP)
KDE61XBR950    ALL    ALL    Iny            TV and Display (TVP)
KDL32XBR950    ALL    ALL    Iny            TV and Display (TVP)
KDL42XBR950    ALL    ALL    Iny            TV and Display (TVP)
KE42XBR900    ALL    ALL    Iny            TV and Display (TVP)
KE50XBR900    ALL    ALL    Iny            TV and Display (TVP)
KLV30XBR900    ALL    ALL    Iny            TV and Display (TVP)
LDM3000    ALL    ALL    Iny            TV and Display (TVP)
LDM3210    ALL    ALL    Iny            TV and Display (TVP)
LDM4210    ALL    ALL    Iny            TV and Display (TVP)
PDM4200    ALL    ALL    Iny            TV and Display (TVP)
PDM4210    ALL    ALL    Iny            TV and Display (TVP)
PDM5000    ALL    ALL    Iny            TV and Display (TVP)
PDM5010    ALL    ALL    Iny            TV and Display (TVP)
PDM6110    ALL    ALL    Iny            TV and Display (TVP)
