Автор Тема: E23919946  (Прочитано 642 раз)
E23919946
« : 07 Сентября 2016, 13:49:32 »
E23919946
Event ID
E23919946   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
2/9/2004 3:10:48 PM
Subject
Image retention
I was watching a channel that displays their logo all of the time. After watching this channel I switched to another station and I could still see a faint image of the logo. Do LCD TV's have image retention?
[Primary Symptom Code: 118X ]
Solution
Yes, LCD TV's, whether direct view or rear projection can have image retention however it will normally correct itself after 1-2 days. If the customer is concerned that this will cause permanent damage they should avoid displaying still images on the screen for extended periods of time. In the event that the image does not go away, image retention is NOT a warranty item.
Model Details
KDL32XBR950    ALL    ALL    Iny            TV and Display (TVP)
KDL42XBR950    ALL    ALL    Iny            TV and Display (TVP)
KF42WE610    ALL    ALL    PTG      LA2   40   TV and Display (TVP)
KF50WE610    ALL    ALL    PTG      LA2   40   TV and Display (TVP)
KF50XBR800    ALL    ALL    PTG      LA1A   40   TV and Display (TVP)
KF60DX100    ALL    ALL    PTG      LA1   40   TV and Display (TVP)
KF60WE610    ALL    ALL    PTG      LA2   40   TV and Display (TVP)
KF60XBR800    ALL    ALL    PTG      LA1A   40   TV and Display (TVP)
KLV30XBR900    ALL    ALL    Iny            TV and Display (TVP)
LDM3000    ALL    ALL    Iny            TV and Display (TVP)
LDM3210    ALL    ALL    Iny            TV and Display (TVP)
LDM4210    ALL    ALL    Iny            TV and Display (TVP)
