Автор Тема: E21896093  (Прочитано 789 раз)
E21896093
« : 07 Сентября 2016, 13:47:09 »
E21896093
Event ID
E21896093   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
9/9/2005 2:29:52 PM
Subject
Cable connecting MRU and display
Customer has unit install on a wall and their cable connecting the media receiver unit and the plasma display has been professionally installed into the wall. How can I service the unit?
[Primary Symptom Code: 118X ]
Solution
It is the customers responsibility to put the TV into a serviceable position. If they installed it on a wall, ceiling, or other hard to reach area the customer will need to get the set into a position that is safe and workable for the tech. For the case where the customer has their cable embedded into the wall or bundled such that it will not allow the technician to connect the two pieces together the technician can take a long an extra cable to connect the two units together. Part number 1-824-831-11 is the standard 3 -meter cable that comes with the unit.
Another possible solution would be to verify the problem prior to removing the TV from its mounted location and then have the customer place it in a serviceable position. Replace the suspected board and then have them re-install the unit to verify that it has been fixed.
One additional note, most custom installs are using a special, longer version of the cable that connects the MRU and display section. For cases of this nature the technician should ask the customer if they have the 3-meter cable that came with the unit so they can use it for troubleshooting.
P/N found in section 5-8 Packing Materials.
Please see E23920721 for additional information about the 10-meter cable often found in custom installs.
Model Details
KDE42XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KDE50XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KDE55XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KDE61XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KDL32XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KDL42XBR950    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
KE42XBR900    ALL    ALL    Iny   11/1/2002   NONE   40   TV and Display (TVP)
KE50XBR900    ALL    ALL    Iny   12/1/2002   NONE   40   TV and Display (TVP)
KLV30XBR900    ALL    ALL    Iny   1/1/2003   NONE   40   TV and Display (TVP)
LDM3000    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
LDM3210    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
LDM4210    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM4200    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM4210    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM5000    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM5010    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM5510    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
PDM6110    ALL    ALL    Iny      NONE   40   TV and Display (TVP)
Associated Parts
Part Number   Reference Number   Description   Symptom Code   Section Code   PCB Reference   Defect Code   Repair Code
182483111    204   Cord with corrector   118X   WIR   NONE    A   A
