Автор Тема: E21008961  (Прочитано 711 раз)
E21008961
« : 07 Сентября 2016, 13:45:27 »
E21008961
Event ID
E21008961   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
11/9/2006 3:59:00 PM
Subject
Lines in pic when using 10-meter cable
When using the VMCP10 optional 10-meter interface cable that connects the media receiver unit to the plasma display lines appear in the picture.
[Primary Symptom Code: 233X ]
Solution
We have had reports of Green, red, or blue lines appearing in the picture when using some
10-meter cables. The first batch of the VMCP10 cables that Sony received from the vendor may create this video problem. If this problem occurs please check the date code on the cable.
It is important to get the DATE CODE on the Box of VMCP10 (see attached JPEG).
All cables with a date code of SF-16L2 (manufactured on December 16, 2002) should be fine.
How to read DATE CODE:
example: SF-02L2
02 : DATE
L : December (K:November , J:October,---)
2 :Year 2002
* This cable manufactured on December 02, 2002. NOTE: There are after market cables available that will also display this problem. In that case, the customer should contact the store that they bought it from and receive a refund.
Please see E23920721 for additional information about the 10-meter cable often found in custom installs.
KDE42XBR950    ALL    ALL    Sony
KDE50XBR950    ALL    ALL    Sony
KDE55XBR950    ALL    ALL    Sony
KDE61XBR950    ALL    ALL    Sony
KDL32XBR950    ALL    ALL    Sony
KDL42XBR950    ALL    ALL    Sony
KE42XBR900    ALL    ALL    Sony
KE50XBR900    ALL    ALL    Sony
KLV30XBR900    ALL    ALL    Sony
LDM3000    ALL    ALL    Sony
LDM3210    ALL    ALL    Sony
LDM4210    ALL    ALL    Sony
PDM4200    ALL    ALL    Sony
PDM4210    ALL    ALL    Sony
PDM5000    ALL    ALL    Sony
PDM5010    ALL    ALL    Sony
PDM5510    ALL    ALL    Sony
PDM6110    ALL    ALL    Sony
