Автор Тема: E20857499  (Прочитано 698 раз)
E20857499
« : 07 Сентября 2016, 13:42:38 »
E20857499
Event ID
E20857499   Type
Service Bulletin    Level
4   Safety Issue
No   AutoFlag
No   Last Update
4/7/2004 12:38:00 PM
Subject
Picture shifted to the right or left
Picture shifted to the right or left by 2 inches or more.
[Primary Symptom Code: 1330 ]
Solution
Have the customer verify that the Media Receiver Unit (MRU) is the correct box for the LCD or Plasma unit. See list below. If the customer has a MRU that DOES NOT match the model above then they received the wrong unit. The customer needs to contact the store in which they bought the unit and get the correct MRU.
For the KE42/50XBR900 (PDM4200/ PDM5000) only use MRU model number MBTXBR900.
For the KDE42/50/61XBR950 (PDM4210/ PDM5010/ PDM6110) only use MRU model number MBDXBR950.
For the KLV30XBR900 (LDM3000) only use MRU model number MBTXBR900L.
For the KDL32/42XBR950 (LDM3210/ LDM4210) only use MRU model number MBDXBR950L.
Model Details
KDE42XBR950    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KDE50XBR950    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KDE61XBR950    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KDL32XBR950    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KDL42XBR950    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KE42XBR900    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KE50XBR900    ALL    ALL    SONY      NONE   40   TV and Display (TVP)
KLV30XBR900    ALL    ALL    SONY   1/1/2003   NONE   40   TV and Display (TVP)
