Автор Тема: Philips SCC_73272  (Прочитано 1520 раз)
Philips SCC_73272
« : 07 Сентября 2016, 13:26:15 »
Philips LCD TV 32PFL5604H 81 cm (32") Full HD 1080p digital TV with Pixel Plus HD
32PFL5604H/12
Q543.3ELA
Symptom
TV does not respond to the RC, or volume bar suddenly appears on the screen.
Cure
MANDATORY:
For all related TV-sets that come into a workshop, it is mandatory to execute action(s) below.
INFO:
It may also have other symptoms as below:
- Volume suddenly increases or decreases by itself while watching TV.
- Local keyboard not working properly.
- Set stuck in "Virgin" mode.
CURE:
Replace IR cable 8M20. The new IR cable must have a black dot on the connector (see figure 1 below).
Refer to below order codes of IR cable for the related CTN (file is also attached).
