Автор Тема: 09TV065R2  (Прочитано 876 раз)
09TV065R2
« : 07 Сентября 2016, 13:05:00 »
EX-2N_Peppermint_AVC Chassis TD
Subject IRIS
Software / Board Upgrade Procedure for “EX-2N with AVC” Chassis [REVISION 2]
This Technical Bulletin describes the upgrading procedure for the “EX-2N with AVC” Chassis, using a USB stick.
Amongst others, an update is needed for software fixes or when exchanging the B board.
Description Part number
B Board A-1732-291-A
1. Preparation
1-1. Take an empty USB stick, and create a folder called “upgrades”.
1-2. Download the following two files, which are attached to Technical Bulletin 09TV066:
“M_AVC_M5Rxx_FHD37_Development.upg” and “WriteNVM_AVC_M5Rxx_FHDxx_MIDxx.upg”.
1-3. Copy both files inside the “upgrades” folder of the USB stick.
