Автор Тема: Grundig BULLETIN NO 2019_20 CHASSIS NX  (Прочитано 34 раз)
« : 03 Августа 2026, 04:16:02 »
07.10.2019
SUBJECT
Project ID selection when chassis is changed at the field
Problem : In NX project, when chassis is changed at the field, the Project ID should be installed to new chassis that will replacing on TV for adjust the correct panel, acoustic and PQ selection settings.
Project ID selection can be made in chassis that has NX.V01.000.00-0010 and upgrade software.
To make Project ID selection at the field, the steps at below should be followed.
1. When chassis that will be at the field starts , the picture at below will be on the TV screen. Project ID that should be entered on the screen is on the TV's back cover. Project ID should be entered with numerical buttons of remote controller.
Sample Project ID is on the TV's back cover: 4003
The numbers should be same on TV's back cover and TV screen
Make sure that Project ID on the TV's back cover value entered correctly to the TV screen. After entering Project ID it will be asked "Are you sure you want to set project ID as 4003 ? This operation cannot undone ! " like picture at below. It should be choosing "Yes" after be sure. If Project ID is wrong, it should be choosing "No" and should be entered correct Project ID value.
