Автор Тема: Firmware update to v9.139 for Asia Pacific  (Прочитано 597 раз)
« : 16 Февраля 2026, 15:46:54 »
KLV-32W512D KLV-32W562D KLV-40W562D KLV-48W562D KLV-43W752D KLV-49W752D
Check the software version
Your software may already be up to date. If you're not sure, it's easy to check which software version you have - follow these instructions:
    Turn on your TV and press the HOME button on the remote to display the Home Menu.
    Navigate to Settings, and press Enter.
    Navigate to Customer Support and press Enter.
    The model and software version should be displayed on the top right-hand corner of the screen: v9.139 - if the version number is v9.139 or higher, you already have the most recent firmware.
There are 2 ways to update the firmware on your BRAVIA TV:
    Using the Automatic Software Download function (easy)
    Using a USB storage device
Using the Automatic Software Download function (easy):
Sony provides software updates in order to enhance functionalities and provide users with the latest TV experience. The easiest way to receive software updates is to use the Automatic Software Download. This setting is enabled by default.
If you have enabled Automatic Software Download below, you will automatically receive a notification to update your TV.
    Press the HOME button on the remote.
    Select Settings, and press Enter.
    Select Customer Support and press Enter.
    Select Automatic Software Download.
    Select On to download the software automatically. Select Off to disable it.
The new firmware update will be rolling out gradually to all Internet-connected TVs over the weeks following its release.
IMPORTANT: The following "System Requirements," "File Info," and the "Download & Install" sections relate to the USB storage device update procedure. You can ignore them if you completed the update using the "Automatic Software Download" feature.
For other FAQs about Troubleshooting, please see the Questions and Answers on the Sony Support Site.
Using a USB storage device:
You can also update the software by using a USB storage device. If an Internet connection is not set up on your TV, or you don’t want to wait for the update via Automatic Software Download function, try to download and update using a USB storage device as instructed below.
