Автор Тема: BU4238  (Прочитано 1808 раз)
BU4238
« : 29 Декабря 2015, 17:54:39 »
LCD200804 4 Pages Ref: BU4238
Product: LCD TV Date: 4/23/08
Models: 26LV47, 26LV67, 32LV67 and 32LV67U
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety
precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety
features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to
possible injury.
Application: The information contained in this bulletin applies only if you encounter the
symptom(s) listed below.
Subject: Dislodged DVD Drive Clamper
Symptom: DVD player fails to play or DVD disc found stuck in the player
Cause: DVD drive clamper disc dislodged from its holder
Solution: Use the following procedure to repair the DVD mechanism assembly:
1) Remove the DVD Drive Mechanism from the LCD TV.
2) Remove the two (2) Phillips screws and unplug connector as shown in Figure 1.
