Автор Тема: Grundig Using 052T50HK1A  (Прочитано 728 раз)
« : 11 Августа 2025, 14:33:33 »
Using 052T50HK1A
Dear Authorized Services,,
This bulletin describes Using 052T50HK1/A cell instead of 052T50PD2/A/B and 052T50PD1/A in 50” Ocean/Charlie2/Charm NX/AN/NE/GX/FX chassis products.
PURPOSE
Service information
In 50” Ocean/Charlie2/Charm cabins, the use of 052T50HK1/A cell electrically instead of 052T50PD2/A/B will be made according to the table below. Mechanically, both cell versions are compatible with each other.
Note: In addition, according to the word file given in the bulletin for the yellow marked 056 panel codes specified in the table below, according to all chassis and cabin groups, the project ID update should be done separately.
Cell
056 code
Cabinet
Chassis
Tcon code
Vby1 cable
FFC cable(2 pcs.)
052T50PD2/A/B
056T50 B12/A/B
Ocean/
Charlie2
NX/ AN /GX/FX
YAM120R
WCW502R-1
ZTC507R
052T50PD1A
056T50 A61A/A62
xxx
xxx
xxx 052T50HK1/A 056T50 A45/A YBE120R ZZX502R-2 WMD507R
052T50PD2/A/B
056T50 B13/A/B
Charm
AN/NE
YAM120R
WCW502R-2
ZPN507R-1
052T50PD1A
056T50 A57A/A58A
xxx
xxx
xxx 052T50HK1/A 056T50 B32/A
YBE120R ZZX502R-4 WMD507R-1
