Автор Тема: PDP200404  (Прочитано 942 раз)
PDP200404
« : 24 Октября 2015, 10:50:34 »
Ref: WU041504
Product: Plasma TV Date: 04/15/04
Models: 42HP82
This Technical Bulletin serves as a supplement to the original Service Manual. (File 050-200220) Please refer to this bulletin in conjunction with the original Service Manual when servicing this model.
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the indicated models and is for information only.
Subject: AD cable connector not fully seated
Symptom: No Picture or Vertical Lines present in the picture
Corrective Action: Remove the Main Video and Audio Modules using the disassembly procedure as described in the Service Manual. Inspect the AD cable harness at connector CN101 on the Main Display Panel for an incorrectly seated plug. The AD cable connects the Main Display Panel to the Main Video / IO Panel. See Figure 1.
