Автор Тема: PDP200403  (Прочитано 910 раз)
PDP200403
« : 24 Октября 2015, 10:49:27 »
Ref: WU040104
Product: Plasma TV Date: 04/01/04
Models: 42HP83
This Technical Bulletin serves as a supplement to the original Service Manual. (File010-200314) Please refer to this bulletin in conjunction with the original Service Manual when servicing this model.
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the indicated models and is for information only.
Subject: Module Assembly Parts Lists
Information Item: The following chart provides major module assembly part numbers for Plasma-TV Models 42HP83. Refer to this listing to identify the correct module part numbers for the model being serviced. Refer to the “Layout of Major Boards” in the service manual for location detail of the modules. (Note: The “Board ID Number” may be screened on the PC board assembly or located on a tag affixed to the module.)
