Автор Тема: LCD200401  (Прочитано 804 раз)
LCD200401
« : 24 Октября 2015, 10:05:51 »
Ref: WU32304
Product: LCD TV Date: 3/23/04
Models: 26HL83 and 32HL83
This Technical Bulletin serves as a supplement to the original Service Manual, file number (010-200311 / 12). Please refer to this bulletin in conjunction with the original Service Manual when servicing this model.
Product Safety Precautions:
Product Safety Precautions are described in the Toshiba service manual(s) for models covered in this bulletin. All safety precautions and checks shall be complied with before returning the equipment to the customer. Servicers who defeat safety features or fail to perform safety checks may be liable for any resulting damages and may expose themselves and others to possible injury.
Application: The information contained in this bulletin applies only if you encounter the symptom(s) listed below.
Subject: Connections between the Scaler and OSD/Micon Module Assembly
Symptom: Multiple Symptoms, depending on which pins exhibit the connection problem. Symptoms of dead set, no picture, picture all one color, intermittent picture or shutdown have been reported.
Corrective Action: Inspect and re-solder connections as necessary on plug PF01 on the OSD/Micon module and socket PJ109 on the Scaler Module. Refer to Fig. 1 for module assembly location and Fig. 2 for plug connector locations of PJ109 and PF01.
