Автор Тема: ASC20070502002  (Прочитано 869 раз)
ASC20070502002
« : 28 Августа 2015, 18:23:27 »
02-May-2007
MODELS: HPT4264X,HPT5064X
HPT4234X,HPT5034X
HPT4254X,HPT5054X
SYMPTOM: If AC power is lost and restored after setting the on/off timer,
the set will auto turn off after 5 seconds of turn on.
SOLUTION: Refer to software version in table.
1. Go to GSPN to download the latest firmware upgrade version.
REPAIR: TO OVERIDE THE SHUTDOWN PROCESS.
1. Turn the TV on and before it goes into shutdown,
unplug TV from the AC power.
2. When you plug the AC back in, the set will operate normally
allowing the firmware upgrade.
