Автор Тема: ASC20080402002  (Прочитано 927 раз)
ASC20080402002
« : 28 Августа 2015, 18:10:27 »
April 2, 2008
MODELS: A330; A450 series
Chassis N45B
SUBJECT: No audio via HDMI connection
SYMPTOM: Some customers have been reporting "There is no audio when using
the HDMI connection from any device".
REPAIR: This problem can be corrected with the software upgrade version 1006.3
applied on 2008-03-01
PROCEDURE:  Verify the software version currently installed by:
1.  Press the “Menu” button on the remote control
2.  Press the  or button to select “Setup” and then press “Enter
Previous version Latest Version
T-CRLAUSC-1002 T-CRLAUSC-1006.3
T-CRLAUSC-1002.5
T-CRLAUSC-1005.1
3.  Press the or button to select “SW Upgrade” and then press “Enter”
4.  Press the “Info” key, the software version will be displayed at the bottom of
the on-screen menu.
5.  If the version is 1002; 1002.5 or 1005.1, perform software upgrade.
6.  After you successfully perform the software upgrade, recheck software
version
7.  Once you have verified software version 1006.3 has been loaded, check for
