Автор Тема: ASC20070502001  (Прочитано 896 раз)
ASC20070502001
« : 28 Августа 2015, 17:59:31 »
02-May-2007
MODELS: LNT3253HX,LNT4053HX
LNT3242HX,LNT4042HX
LNT4642HX,LNT4061FX
LNT4661FX,LNT4065FX
LNT4665FX
SYMPTOM: If AC power is lost and restored after setting the on/off timer,
the set will auto turn off after 5 seconds of turn on.
SOLUTION: Refer to software version in table.
1. Go to GSPN to download the latest firmware upgrade version.
REPAIR: TO OVERIDE THE SHUTDOWN PROCESS.
1. Turn the TV on and before it goes into shutdown,
unplug TV from the AC power.
2. When you plug the AC back in, the set will operate normally
allowing the firmware upgrade
