Автор Тема: UN60C6300QFXZA  (Прочитано 1194 раз)
UN60C6300QFXZA
« : 25 Августа 2015, 10:05:14 »
Fast Track Troubleshooting Manual Rev – 5/7/12
If the unit continuously goes into Demo mode after setting it for Home use, verify front touch sensor operation. If any or all of the buttons do not respond, make sure 5v is present from the main board. If so, replace the touch sensor. The touch sensor in these models is difficult to access due to the plastic reinforcement along the bottom of the front cover, so the entire front cover may have to be replaced.
8/9/2010
(1010 & 1005.0)
Reason: This firmware will prevent:
'USB Power Overload' message pops up even USB port is not connected
HDMI 2 looks activated when HDMI 1 port is connected
Previous: 1006.1
Prevents :Buffering when connecting Samsung Camcorder S15 and 16 through
