Автор Тема: UN46C6900VFXZA  (Прочитано 738 раз)
UN46C6900VFXZA
« : 24 Августа 2015, 13:11:34 »
Fast Track Troubleshooting Manual Rev –1/12/12
If the unit continuously goes into Demo mode after setting it for Home use, verify front touch sensor operation. If any or all of the buttons do not respond, make sure 5v is present from the main board. If so, replace the touch sensor. The touch sensor in these models is difficult to access due to the plastic reinforcement along the bottom of the front cover, so the entire front cover may have to be replaced.
2/21/2011
(T-VALAUSC, 1035.0)
Reason: Support Netflix 2.1 and MLB.tv apps.Support new TV camera (Model: CY-STC1100).Add "3D Optimize" option on Menu for better 3D image.(Only LCD/LED TV)
Previous: 1032.0
Prevents:
-USB Power Overload' message pops up even USB port is not connected
-Plug & Play is displayed uponpower up.
