Автор Тема: 12-TV-N063  (Прочитано 791 раз)
12-TV-N063
« : 17 Августа 2015, 15:34:57 »
Repair Code for repair without parts
Repair
Repair
Code
Definition
Soldering /
Welding
B01
Melt and flow solder into the joint,
when component parts are not combined tightly
with PCB.
Reconnect /
Re-assembling
M11
If problem is caused by loosen connection,
separate cable from connector and
connect cable again firmly.
※ Connection problem
- cleaning connector then reconnect it
Mechanical
Adjustment
C99
Fixed the pinched wire
Re-assemble the Rear Cover
Tighten the loose screw
Remove the particle inside the TV (there are 4 cases of the repair without parts)
Factory mode
Adjustment
C05
Adjust or change the value in Factory mode (Service mode)
Factory Reset
Electrical
Adjustment
C09
Adjust the Voltage of PDP TV
Software
Upgrade
H01
Upgrade the Software with new version.
