Автор Тема: 12-TV-N060  (Прочитано 722 раз)
12-TV-N060
« : 17 Августа 2015, 15:32:33 »
Service APP New Service Bulletin Registration
2012-07-30
Title
Keyword LED ES6K Pop-up(Y/N)
SVC Number 12-LED-T CON DC-DC
Production Range All
(Please select from Drop down Menu) (Please select from Drop down Menu)
Symptom No Picture Item T Con
- Picture1 - Picture2
No picture T-con DC-DC conv. Defect
Model or Project LED ES6000 Series
Cause
When the power is on, the screen doesn't work but the
audio is out normally.
It's Panel Source B'D defect
Measure T-CON with a digital multi-meter.
→ Measure the DC-DC IC voltage of T-CON B'D. If it's
unable to measure, recheck the condition as the
following.
① Detach FCC(Source PCB-A,B) from T-CON & Panel
Source PCB, and measure in the same way. If the voltage
is out normally, it is a defect on Panel Source PCB.
② If the voltage is not out, it is a defect on DC-DC IC of
T-CON B'D. So replace the T-CON B'D.
Solution
