Автор Тема: TFP1508I022  (Прочитано 1009 раз)
TFP1508I022
« : 11 Мая 2024, 19:09:09 »
TFP1508I022
TH-43LFE8C VED1507563CC
TH-48LFE8C VED1507564CC
TH-55LFE8C VED1507565CC
EA5742
TH-43LFE8U/E/W VED1505560CE
TH-48LFE8U/E/W VED1504554CE
TH-65LFE8C VED1507566CC
TH-55LFE8U/E/W VED1505559CE
7th Aug, 2015
There was a case that the image was black out about once between 30 minutes to 3 hours
when PAL signal was input.
The image signal (PAL signal) had been miss judged as non-signal state then the image was
black out.
There was a case when the signal from repeating operation of USB media player was input,
2nd time (and later) playback was not showing on the display.
Playback of moving image from USB might take time for STOP/PLAY process it caused miss
judgement of signal detection.
TH-65LFE8U/E/W VED1505558CE
