Автор Тема: TRB0005 REV09  (Прочитано 945 раз)
TRB0005 REV09
« : 19 Марта 2024, 19:51:59 »
TRB0005 REV09
TPVISION CONSUMER CARE
TECHNICAL RETAILER BULLETIN
OLED set asks for clearing residual images after start-up in shop mode from power-off state
Reference
Date
#0005 (REV09)
02.12.2019
Affected SW version(s)
Fixed with SW version
>=TPM171E_107.000.222.001
>=TPM171E_105.001.002.084
N/A
Affected model(s)
55POS9002/12
65OLED854/12
55OLED803/12
55OLED934/12
65OLED803/12
65OLED934/12
55OLED903/12
65OLED984/12
65OLED903/12
55OLED805/12
65OLED873/12
65OLED805/12
65OLED973/12
55OLED855/12
55OLED754/12
65OLED855/12
65OLED754/12
55OLED865/12
55OLED804/12
65OLED865/12
65OLED804/12
48OLED935/12
55OLED854/12
65OLED935/12
ATTENTION
Please make sure that the TV is running in shop mode as otherwise some of the measurements that are implemented for burn-in prevention & reduction might not be efficiently working to accommodate shop requirements.
ATTENTION
In order to ensure the maximum level of burn-in risk reduction in shop environments, please make sure that 2k17&2k18 OLED sets are upgraded to the latest available SW version, regardless of operating conditions (at least the following versions, depending on the model):
➢ TPM171E_107.000.222.001 (POS9002; OLED873; OLED973); the latest official SW release for these models can be found here
➢ TPM171E_105.001.002.084 (OLED803; OLED903); the latest official SW release for these models can be found here
SITUATION
If the TV is powered on in shop mode, the TV set will immediately ask for a display refreshing cycle. The cycle will be automatically executed after a pre-defined countdown of 30 seconds has elapsed and cannot be delayed.
