Автор Тема: TAOSC- CTV-02A-200219  (Прочитано 775 раз)
« : 04 Июня 2015, 19:37:27 »
29AF7UC, 29AF8UC, 29AF9UC, 29AX8UG, 29AX8UH, 29AX9UH, 29AX9UM, 29AZ8UA, 29AZ8UC, 29AZ8UE, 29AZ8UG, 29AZ8UM, 29AZ8UR, 34AF8UC, 34AF9UC, 34AX8UG, 34AX9UA, 34AX9UE, 34AX9UH, 34AX9UM and 34AX9UR
Symptom:
Noisy picture, compare with previous models, appears if RF signal is week.
Since, put first priority on Brightness and Sharpness in default setting for those models, noise components are also enhanced.
Corrective Action:
Reduce Brightness and Sharpness by changing memory data.
Refer attached table.
Required parts:
