Автор Тема: TAOSC-PJTV- 04A-200107  (Прочитано 779 раз)
« : 04 Июня 2015, 19:22:47 »
Model: 44G9UXE, 44G9UXC, 44G9UXH, 44G9UXK, 44G9UXM
Spare parts change notice
Spare part of EEPROM (QB02) has been changed as following details.
Required Parts:
Corrective
action: Note:
1. Use 23009084 for the set which has QX300 on the Upconverter
PCB, U906.
2. Use 23009085 for the set which has not QX300 on the Upconverter
PCB, U906.
3. Do not initialize the new EEPROM after replacement.
4. Picture will be abnormal, like out of purity control or yellowish
picture, if the previous type of EEPROM P/N:
23905320 is used as replacement parts.
From
To
Location No.
QB02
Part No.
23905320
23009084
23009085
Description
IC, NM24C16EN
IC, CAT24W16P
IC, CAT24W16P
Vendor
DJ0(J)
DJ0(J)
DJ0(J)
Marking
009084
009085
