Автор Тема: TAOSC- PJTV-20020912-01 revise  (Прочитано 858 раз)
« : 04 Июня 2015, 19:03:55 »
Model: A9 series
Required Parts:
Countermeasure: Replace the Resistor with new ones at .
From
To
Location No.
RH009
Part No.
Description
10Kohm Resistor
Vendor Marking
1 /1
FILE NO. TAOSC- PJTV-20020912-01 revise Date : 30 September 2002
Technical Tip
TOSHIBA ASIA OCEANIA SERVICE CENTRE
TOSHIBA SINGAPORE PTE. LTD.
438B ALEXANDRA ROAD, BLOCK-B
#06-05 ALEXANDRA TECHNOPARK,
SINGAPORE 119968
PHONE : (65)62762022
FAX : (65)62762322
RH009
47Kohm Resistor
ZC01 23148784 MODULE,D-CONVER,MDCC11
With problem convergence out of range after user 's adjustment in user’s
convergence mode (After a few days or some case just turn off and turn on
again then, the convergences fail again).
