Автор Тема: 20TV029R2  (Прочитано 604 раз)
20TV029R2
« : 07 Декабря 2023, 08:47:03 »
20TV029R2
Models
KD-75XH92xx, KD-75XH90xx, KE-75XH92xx, KE-75XH90xx, FW-75BZ40H
Subject: T-con Board Replacement [REVISION 2].
Different non-compatible T-con boards for the listed model have been registered for service.
CAUSE
Manufacturer change.
In case of any T-con board failure replace the T-con board according to the part number info below.
SVC P-Mod Assy
O-cell
T-con
Description
Sony P.N.
Vendor P/N
Sony P.N.
Sony P.N.
NX75, Black Bezel
A-5016-527-A
YDAS075DND02
1-007-576-11
100757611
NX75, Silver Bezel
A-5020-659-A
NXB75, Black Bezel
A-5016-558-A
NX75, Black Bezel
A-5024-285-A
YDAS075DNS02
1-009-555-11
100955611
NX75, Silver Bezel
A-5024-296-A
NXB75, Black Bezel
A-5024-290-A
How to identify:
IMPORTANT: When the T-Con board is replaced please apply the ‘ WB/Mura/CUC data transfer ‘ ( SoC to T-con ) like described in the Common Service Manual available in ASSIST. ( in ‘ Service mode ‘ select ‘’ Panel/PQ ‘’ - “ WB/Mura/CUC data transfer ”- )
