Автор Тема: 18TV006R9  (Прочитано 1080 раз)
18TV006R9
« : 06 Декабря 2023, 11:48:26 »
18TV006R9
Models
GN4UN_CP Chassis
Subject: Software packages follow-up for GN4UN_CP chassis [REVISION 9].
SW version: 8.609
Link: sony_tvupdate_2017_8609_enf_auth.zip
The latest software packages have been released, both enriching the set with additional features and remedying specific issues.
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-760-0x.
1. Download the applicable file from the link mentioned in the header, unzip and copy the extracted file to the root of an empty USB stick.
2. Turn the unit ON.
3.A series of different messages will appear on the TV set. Please follow the on screen instructions
4. During System update, the LED indicator slowly flashing amber.
5. After several minutes, the Software update complete message displays. And the TV will turn off automatically and then turn back on to complete the update. IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set or remove the power.
6. After the TV turn on, Safely remove your USB device from the USB slot
REVISION HISTORY
DTV02B40B0AB4BE_00100100_8609
