Автор Тема: 17TV022R16  (Прочитано 1005 раз)
17TV022R16
« : 06 Декабря 2023, 10:31:52 »
17TV022R16
Models GN3UN_KC Chassis
Subject: Software packages follow-up for GN3UN_KC chassis [REVISION 16]
SW version: 8.931
Link: sony_tvupdate_2017_8931_eff_auth.zip
SW version: 8.535
Link: sony_tvupdate_2017_8535_eff_auth.zip
The latest software packages have been released, both enriching the set with additional features and remedying specific issues.
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-741-0x.
1. Download the applicable file from the link mentioned in the header, unzip and copy the extracted file to the root of an empty USB stick. NOTE: Update to 8.674 or above can only be done if 8.533 or 8.535 is already installed. If SW version currently in TV is older than 8.533, please download and install 8.535 first before you update to 8.674. NOTE: Update from 8.533 to 8.535 is not needed and not possible.
2. Turn the unit ON.
3. Insert the USB memory into the USB port located at the side of the unit.
4. Go to USB update
Press [HOME], and select ‘Settings’ > ‘Customer Support’ > ‘Software Update’ > ‘USB’
5. A series of different messages will appear on the TV set. Please follow the on screen instructions.
6. During System update, the LED indicator slowly flashing amber.
7. After several minutes, the Software update complete message displays. And the TV will turn off automatically and then turn back on to complete the update. IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set or remove the power.
8. After the TV turn on, safely remove your USB device from the USB slot.
DTV02B40B09B4BD_00200100_8931
