Автор Тема: 16TV033R0  (Прочитано 467 раз)
16TV033R0
« : 06 Декабря 2023, 07:35:06 »
16TV033R0
Models
KD-65XD9305, 55XD9305
Subject: No power and no LED activity
No Power and No LED blinking
No voltage output at CN400 pin 1 on DPS board. It should be 3.3V.
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number (3C)
Ref.
(pre3C)
Section
code
Defect
code
Repair
code
Reactive (issue listed) 1 111 16TV033 16TV033 DPR N A
Check point
2 / 2
CAUSE
IC408 on DPS board might be broken.
Replace the DPS board with the correct Part number like indicated in the Service Manual.
