Автор Тема: 16TV031R0  (Прочитано 451 раз)
16TV031R0
« : 06 Декабря 2023, 07:32:37 »
16TV031R0
Models
KDL-40WD65x, 32WD60x, 40RD45x, 32RD43x
Subject: Loudspeaker compatibility.
Two different non compatible speakers are available.
CAUSE
Manufacturer change.
Whenever replacing a loudspeaker, make sure to use Loudspeaker of the same suffix. Don’t mix original Loudspeaker
with new suffix Loudspeaker. Replace as long as available with the original P.N.
Description Part number
Loudspeaker (original) 1-859-166-11
Loudspeaker (new) 1-859-166-21
