Автор Тема: 17TV006R1  (Прочитано 1171 раз)
17TV006R1
« : 06 Декабря 2023, 07:24:32 »
17TV006R1
Models
GN3TR_KA, KP, KS, KH, KF Chassis
Subject: Software packages follow-up for GN3TR chassis [REVISION 1].
The latest software packages have been released, both enriching the set with additional features and remedying
specific issues.
REMEDIED ISSUES
Issues
IRIS
code
Section
code
Segment Rev.
Initial Service Release R0
DVB-T2 compatibility update for MEDIA BROADCAST GmbH (Germany) D21A DPR ALL
No sound from specific Ultra HD blu-ray disc F575 APD ALL R1
Satellite channel sorting improvement C264 SWA ALL
Update with the latest software package, following the abridged procedure below.
IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set,
remove the power or do not press any other button except as instructed until the update is completed.
The firmware update process may take up to approximately 15 minutes.
For on-site service event we recommend to advise the customer to do a software update before going on-site.
NOTE: For full software procedure please check Service Manual.
1. Download the applicable file from the below link, unzip and copy the extracted to the root of an empty USB
stick.
Date Attachment Version in TV menu
15 March 2017 sony_dtvota_2016_1601004100_eua_auth.zip PKG6.1004.0010 EUA
2. After AC plug-in, wait for 20s then turn the unit ON via [POWER] button on remote.
IMPORTANT: It is necessary to wait 20s for successful FW writing.
3. Insert the USB stick into the USB slot located at the side of the TV set.
4. A series of different messages will appear on the TV screen - follow the on screen instructions.
ASC REPORTING
Repair type
Condition
code
Symptom
code
Part
number (3C)
Ref.
(pre3C)
Section
code
Defect
code
Repair
code
Proactive (NPF) 17TV006 17TV006 SFT 6 2
Reactive (issue not listed) 17TV006 17TV006 1 2
Reactive (issue listed) issue issue 17TV006 17TV006 issue 1 3
2 / 2 17TV006 R1
5. First, the TV will copy update file from USB, then the POWER indicator will start flashing under updating process (White colour).
An Update progress screen will be shown on screen under updating.
6. After several minutes, the TV will turn off and then turn back on to complete the update.
CAUTION: During the firmware installation process, do not remove the USB device, switch off the TV set or remove the power.
7. When the firmware update is complete, a message is displayed on the TV. It is now safe to remove your USB device from the USB slot.
DTV0FA60A0AA0AA_00004100_16010041000010
« Последнее редактирование: 07 Декабря 2025, 09:41:41 от aze1959 »
