Автор Тема: 16TV013R0  (Прочитано 258 раз)
16TV013R0
« : 06 Декабря 2023, 04:40:10 »
16TV013R0
Chassis:
GN2SK QF
Models:
KD-55XD9305; KD-65XD9305
Subject: TV Set/Panel Handling Precautions (XD93)
PROBLEM:
If the TV set or panel is handled roughly, this can cause warping, scratches or other damage. The TV set handling precautions
are similar to the panel handling precautions basically.
INSTALLATION/SETUP (END USERS):
 Keep the protective cover until the TV set is installed.
 Hold the TV set in a vertical position (Do not lay TV set down or hold it with the screen facing up or down.)
 One-man handling is prohibited
WORKING ON TABLE:
 Put a soft and clean sheet on the table when you put the TV set or panel.
 Be careful there is nothing on the table such as dust, scrap, screw, etc., to avoid scratching the aluminium frame or the
screen surface
 Use “rubber gloves” when handling the panel
2/4
Sony Europe Limited
Service, Quality and Environment
Service Engineering
 We recommend a spacer cushion. Refer to the drawing below for the size of the spacer cushion (15~50mm from aluminium frame.)
 To prevent scratch damage, do not let the Edge Coat area touch the table surface.
