Автор Тема: Philips SCC_71772  (Прочитано 1563 раз)
Philips SCC_71772
« : 15 Апреля 2015, 18:47:40 »
Symptom
After replacement of the SSB, the TV is in protection (error "2") and will not start.
Cure
INFO:
This can be caused by the audio protection, because the SSB is probably used without the loudspeakers connected.
CURE:
Be sure to reconnect the loudspeakers after replacing the SSB. This means e.g. for sets with an "ME8" or "ME8+" styling, to mount the rear cover. For other stylings, just connect the speaker plugs before testing the set.
For more info, see also GSC_68641 "Extra attention needed when mounting the TV backcover (ME8) after repair".
