Автор Тема: 16TV006R3  (Прочитано 440 раз)
16TV006R3
« : 06 Декабря 2023, 04:00:14 »
16TV006R3
Models
GN2S_QW Chassis
Subject: Software packages follow-up for GN2S_QW chassis [REVISION 3].
The latest software packages have been released, both enriching the set with additional features and remedying
specific issues.
ADDITIONAL FEATURES
Features
IRIS
code
Section
code
Segment Rev.
Support IPTV services (YouTube/Netflix/Opera Apps/CEB) C231 DNS QW R0
REMEDIED ISSUES
Issues
IRIS
code
Section
code
Segment Rev.
TV set no operation (Green LED light comes on, but screen stays black) V11F FMW QW R3
ASC REPORTING
Repair type
Condition
code
Symptom
code
Part
number
Ref.
Section
code
PCB
Defect
code
Repair
code
Qty.
Proactive (NPF) 16TV006 SFT 6 2
Reactive (issue not listed) 16TV006 1 2
Reactive (issue listed) issue issue 16TV006 issue 1 3
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-196-xx.
1. Download the ZIP file (see link), unzip it and copy the extracted file to the root of an empty USB stick.
Date Link SW version
12 April 2016 GN2S_QW_v8056_TDEUA.zip 8.056
2. Turn the unit ON.
3. Insert the USB memory into the USB port 1 located at the side of the unit.
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor).
5. Press the key located on the lower part of TV and hold it while inserting the AC plug.
2 / 3 16TV006 R3
Sony Europe Limited
Service, Quality and Environment
Service Engineering
2 / 3
6. Continue to hold the
key while confirming the LED status.
Amber LED blinking indicates that the SW Update is ongoing. IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set or remove the power.
7. After 1~2 minutes, the LED stops blinking and the TV will turn ON. If “SONY” appears on the screen and the LED turns ON in green, the software update succeeds.
8. Pull out the USB memory from the unit.
9. Confirm the SoftWare version
10. Change UART selection in Service Mode to ‘ NoLog’.
a. Go into service mode ( [ i ] > [ 5 ] > [ vol+ ] > [ TV POWER ]
b. Press [ DOWN ] key to select “UART Selection”.
c. Press [ RIGHT ] key 4 times to change from Factory  No Log.
d. Press “ENTER” to select
e. Press [ POWER ] key to go to StandBy and leave Service Mode.
