Автор Тема: 15TV030R0  (Прочитано 241 раз)
15TV030R0
« : 06 Декабря 2023, 03:14:23 »
15TV030R0
Models
KD-65X9005C, 55X9005C
Subject: SP-BOX ASSY replacement notice.
Two different non compatible SP-BOX ASSY (D20-WF) are available. With or without AL tapes.
CAUSE
Design change to SP-BOX ASSY without AL tapes.
Whenever replacing, make sure to use a SP-BOX ASSY of the same suffix. Don’t mix original SP-BOX ASSY with
AL tapes with SP-BOX ASSY without tapes.
In case of replacing SP-BOX ASSY with AL tapes with SP-BOX ASSY without tapes, please replace both Left and
Right SP-BOX. Remove also the HEAT SINK (both Left and Right) and the AL tapes as illustrated in the below
pictures.
Location of parts to be deleted
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number
Section
code
Defect
code
Repair
code
Reactive Part P.N. SPK A
2 / 2
Use the part number info in the table below to order compatible SP-BOX ASSY (D20-WF).
Description Part number Appearance
With AL tapes
SP-BOX ASSY (D20-WF LCH CH-ND) 1-859-108-11
SP-BOX ASSY (D20-WF RCH CH-ND) 1-859-108-21
Without AL tapes
SP-BOX ASSY (D20-WF LCH CH-ND) 1-859-108-51
SP-BOX ASSY (D20-WF RCH CH-ND) 1-859-108-61
