Автор Тема: 15TV026R0  (Прочитано 252 раз)
15TV026R0
« : 06 Декабря 2023, 03:09:54 »
15TV026R0
Models
GN1T, GN1G Chassis
Subject: Touch Pad Remote controller (TPR) does not work
Case 1: TV can only be operated by using the paired TPR that is bundled with the set.
Case 2: TPR does not work after factory reset by infrared remote.
Case 3: TPR does not work due to Bluetooth connection failure.
CAUSE
Case 1: Product specification
Case 2: Product specification
Case 3: Various circumstances of radio communication
Note: TPR is connected with TV via Bluetooth.
Case1: TV can only be operated by using the paired TPR that is bundled with the set.
 TV and TPR are paired one-to-one.
 TV can be operated only by the paired TPR.
 TPR will be paired with the bundled TV automatically when first used.
If you want to pair with another TV, please follow the procedure ‘ How to pair TPR with TV ‘ below in this
document.
