Автор Тема: 16TV005R0  (Прочитано 384 раз)
16TV005R0
« : 06 Декабря 2023, 03:00:43 »
16TV005R0
Models
GN2S_QWL Chassis
Subject: Software packages follow-up for GN2S_QWL chassis.
The latest software packages have been released, remedying the issues below.
Issues IRIS code Section code Segment Rev.
Wrong ‘electronic Pre-installed Onscreen Promotion’ in Demo mode. C739 SWA ALL R0
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-196-xx.
1. Download the applicable file attached to this Technical Bulletin, unzip and copy the extracted file to the root
of an empty USB stick.
Date Attachment SW version
March 2016 GN2S_QWL_v8513_TDEU1.zip 8.513
2. Turn the unit ON.
3. Insert the USB memory into the USB port 1 located at the side of the unit.
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor).
5. Press the key located on the lower part of TV and hold it while inserting the AC plug.
gn2s_qwl_v8513_tdeu1
