Автор Тема: 15TV011R0  (Прочитано 230 раз)
15TV011R0
« : 05 Декабря 2023, 16:58:21 »
15TV011R0
Models
KD-75X9405C
KD-85X9505B
Subject: Caution when replacing G6 STATIC CONVERTER board.
Caution for G6 board Terminal ground
CAUSE
Same G6 board is used for different models with different EMC counter measure.
In case of G6 board replacement for KD-75X9405C
- remove Terminal Ground (ET6401) when you replace G6 board (1-474-576-11)
- highly recommend doing it by finger
- Don’t recommend nipper cut to avoid board damage and lose conductive material to anywhere
In case of G6 board replacement for KD-85X9505B
- No modification needed (use with Terminal Ground).
