Автор Тема: 15TV002R0  (Прочитано 288 раз)
15TV002R0
« : 05 Декабря 2023, 15:19:54 »
15TV002R0
Models
ITC3_ME Chassis
Subject: Automatically switching / Switch Unit replacement
Automatically jump to DEMO MODE, Input Select Menu, ON/OFF due to defect switch unit.
If you disconnect the harness from the ‘Switch Unit’, the set will work normally with the Remote Commander.
Replace Switch unit with improved one with P.N. below
Description Part number
SWITCH UNIT 1-492-517-21
To distinguish which is the improved one please refer to picture below.
‘Product lot no.’ printed on switch unit need to have as last digit ‘3’.
