Автор Тема: 14TV049R1  (Прочитано 242 раз)
14TV049R1
« : 05 Декабря 2023, 13:12:08 »
14TV049R1
Models
RB2-T_HJ, HA, HC Chassis
RB2-G_HT, HE-H, HE-L(3D), HE-L(2D), HM
Subject: Defect Remote Commander RM-ED060 & RM-ED061 [REVISION 1]
1. Does not work at all
2. Continuously sends signal
3. Does not work from certain distance, usually 4 meters
4. Has key stuck
CAUSE
Problem happened during remote commander board manufacturing process.
Cracks were created in carbon-switch pattern and PSR (resist). Cracks make impedance lower between carbonswitch
and copper pattern underneath. Cracks were initially made in PWB process. High temperature and humidity
can influence the symptoms.
Replace the Remote commander with the Part Numbers mentioned in the Service Manual.
Keep the defective Remote Commander during two months, Sony may request it for investigation purposes.
Report accurately like explained below.
 Service accounts uploading in CLARIFY (3C web services): report the case under the TV model name.
 Service accounts uploading in IBISS: report the case under the Remote Commander model name.
 Indicate the correct symptom that the customer claimed after confirmation. Use the IRIS codes like
mentioned in the ASC reporting table below.
 Indicate the part number replaced.
2 / 2
ASC REPORTING
CLARIFY
Symptom
code
Part
number
Section
code
Defect
code
Repair
code
151 14TV049 REM N A2
151 "RC PN" REM N A2
152 14TV049 REM N A2
152 "RC PN" REM N A2
154 14TV049 REM N A2
154 "RC PN" REM N A2
742 14TV049 REM N A2
742 "RC PN" REM N A2
15X 14TV049 REM N A2
15X "RC PN" REM N A2
IBISS
Repair
type
Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Does not work at all * 151 "RC PN" 14TV049 REM N A2 1
Continuously sends
signal * 152 "RC PN" 14TV049 REM N A2 1
Does not work from
certain distance * 154 "RC PN" 14TV049 REM N A2 1
Has key stuck * 742 "RC PN" 14TV049 REM N A2 1
Other * 15X "RC PN" 14TV049 REM N A2 1
