Автор Тема: 15TV009R1  (Прочитано 445 раз)
15TV009R1
« : 05 Декабря 2023, 13:07:01 »
15TV009R1
GN1S_SE2 Chassis
Subject: Software packages follow-up for GN1S_SE2 chassis [REVISION 1]
The latest software packages have been released, remedying the issues below.
Issues IRIS
code
Section
code Segment Rev.
Teletext/Subtitle display position shifted after playback USB
recorded content C37E VPD ALL R0
Improves power saving feature (Idle TV standby and default
setting for Photo Frame mode) H73X SWO ALL R1
Update with the latest software version, by following the abridged procedure below.
NOTE: For full software procedure please check Service Manual 9-888-174-xx.
1. Download and unzip the applicable file attached to this Technical Bulletin and copy the extracted file to the
root of an empty USB stick.
Date Attachment SW version
August 2015 GN1S_SE2_v8076_SLEU1.zip 8.076
2. Turn the unit ON.
3. Insert the USB memory into the USB slot located at the side of the unit.
4. Pull Out the AC plug and wait 10 second (considering the charge of AC adaptor).
5. Press and hold the side Power Key for 5 seconds and re-insert the AC plug at the same time.
After 20~30 seconds, the LED starts blinking in amber.
LED blinking indicates that the SW Update is ongoing.
IMPORTANT: During the firmware installation process, do not remove the USB device, switch off the TV set
or remove the power.
6. After 1~2 minutes, the LED stops blinking.
Press the unit [Power] key.
If “SONY” appears on the screen and the LED turns ON in green, the software update succeeds.
7. Pull out the USB memory from the unit.
ASC REPORTING
Repair type Condition
code
Symptom
code
Part
number Ref. Section
code PCB Defect
code
Repair
code Qty.
Proactive (NPF) 15TV009 SFT 6 2
Reactive (issue not listed) 15TV009 1 2
Reactive (issue listed) issue issue 15TV009 issue 1 3
15TV009 - Software packages follow-up for GN1S_SE2 chassis [REVISION 1]
gn1s_se2_v8076_sleu1
